Mines the Ctek and is straight to battery terminals too and works fine
I had exactly the same problem as this - not on the Zed but my ride on mower. The battery was so flat the trickle charger didn't see it. I put a standard battery charger on for a couple of hours on its own then changed over to the trickle charger and it was fine. Best of luck but if the Zed battery is that flat it may not come back.Ok, the almighty power of Google suggests that the Z battery is just too flat for the CTEK to recognise it's there (bit of an oxymoron but hey ho).
Next question can I just stick a normal charger on it to get it going or will it damage the electrics?
Do you +ve and -ve posts under the bonnet on Z3s?Just tried putting the negative to the body (difficult as most bits within reach are plastic!) but hasn't worked either. I've tried another stand alone battery and that works fine so I'm stumped now. Last resort will be dismantling the terminal connectors to try a better contact but I didn't think you had to do that with CTEK
Agree - same in most cars. if you can get it up and working for a short while it might get you a few days grace though.Once the battery on a zed goes flat it is normally the death of them and time for a new one.
Totally agree Pete, mines a Lidl one alsoHowever I recommend you get a CTEK as you may possibly have plenty of money for something that will do exactly the same.. but you sure will feel superior about it in the knowledge that it cost 5 x the price and you can look down on our menial purchases thinking they can't possible keep a battery going for 5 months, ......... (whereas I know differently)
In the summer it certainly isn't a problem but regular overnight -3 to -5 temperatures soon run your battery down. Little more than a week can see mine struggling to start.I'm personally not into trickle charging. If you have a good battery it will hold the charge for some time, certainly a month or more between starts. That said, my car gets used at least every few weeks so i'm no authority on this, just a thought. Cars are best used regularly for all sorts of reasons IMO.
You definitely get what you pay for where batteries are concerned, but mine isn't likely to be the original one on a 2003 car, oh, and my car is a daily use car. They have a life, and that's it!Interesting, mine is also kept in an unheated garage, original BMW battery replaced with OEM battery (BMW) about 6 years ago. Cost about £100 but you get what you pay for IMO. Starts on the button (sorry key!) each time.
