Can anyone suggest a good trickle charger?
Cheers
Paul
Cheers
Paul
Aston Martin have the same one, just a differant badge. If it's good enough for AM .........last time i was in BMW the cars in the show room where being charged with a trickle charger that was identical to a Ctek but it was badged BMW. My neighbour as a trickle charger on his Porsche, this too looks like a Ctek badged as a Porsche
Yep, that's the one I have. The nuts.
Stick it straight on the battery @Rambling, either by the crocodile clips or the spade connectors supplied. Take the bulb out of the boot if you need to.Just bought a CTEK charger - I having to use with an extension lead but the green LED light flashes after a bit indicating its not charging and has gone into power save mode.
Does the negative lead get fixed to the body of the car or the negative terminal like normal battery chargers? The manual isn't very clear!
