Good Morning Zedders, I hoe you are all coping with whats going on, both physically & mentally. Like most I have been tinkering with the Zed recently.
but I have a bit of an techy ask please.
I had the tracking done a couple of months back, this left to car driving fine but the steering wheel off centre. Took it back as I suspected they only adjusted one track rod end. I suspected this as only one track rod showed signs of heat and being worked. Rechecked but wheel in same position, in desperation I moved the wheel on the column to get it central.
Now I have the offside wheel rubbing on the wheel arch on full right lock. Now this did happen a little while ago so I poly bushed the car throughout, so it's not the banjo.
On axle stands I can get my finger between the wheel & bodywork on full lock on the nearside, on the offside the wheel is just rubbing, so about 8 to 10 mm difference. the rubbing is on the bulkhead
I replaced the wishbone yesterday as there was play in one of the ball joints, no difference.The track rod ends look fine,no play
Question is to you techies, if the track rod end was adjusted on the offside only could this be a cause?
Should I get a couple of new track rod ends on then get the tracking done again?
Car has been lowered but not been an issue since I changed the banjo's to poly.
Getting frustrated, any advice gratefully received.
TIA
Stay safe.
TIA
Stay safe.
