Tonneau doing my head in
Jonnysnapzzz
Nottingham
Be careful leaving the hood down, they should be closed frequently to ensure the hood fits correctly, can lead to issues if left open for too long
Thanks Paul, what about people with a hard tip on for periods of time? Surely it’s no different ?
Paul Rice
Doncaster
Z4 2.5 E89 23
Its a manufacturers recommendation (well it was by Ford) to avoid problems with the hood, as Grumps has already had issues, not insurmountable but saves grief with excess stress on the locking mechanism as with age these are vulnerable and at £275 each expensive to replace
Jack Ratt
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
The way I see it is if the soft top is perfectly dry when you put it down it should retain it's shape and not shrink, however if it's damp when you put it down and leave it for an extended period it could shrink as it dries.
I've still got the hard top on my silver zed and it will stay on until I get my storage space back, so I'll report back with my findings
Sean d
Lincolnshire
I agree mate, I store mine with the hood down and when I had my hard top on I had no bother at all, one thing I did notice that was when the hood first saw water after a long period of being dry (when I was restoring the car) it leaked until it had got damp and swelled
Dalek
Highworth, Wiltshire
Z3 2.2i Auto
Watching this as mine does a similar thing.
Lay it out on the ground and it looks fine, but as sion as I fit it and tuck the edge in I get two areas where it bulges in similar to jonnysnapzz pic.
Really annoying.
Sean d
Lincolnshire
Really annoying.
Do you also have a ridge across the top by any chance, the top should sit flat with a gentle roll towards the back and front
Jonnysnapzzz
Nottingham
Ive not had a chance to look again at mine yet, i intended to by a heat gun and do what Sean suggests.
Sean d
Lincolnshire
I have just taken a pic of my mine so you can compare, you can see how flat mine is where as yours has the ridge that I pointed out
Dalek
Z3 2.2i Auto
My tonneau bulges in both sides as shown. I am using the longer studs and clip it down on both the rear and front studs.
