Tommy Bates
hey guys , my name is Tommy Bates
This is my old e36 compact was looking A bit battered after a season of hard drifting and been looking for a excuse to swap everything into a z3 for ages
specs of everything being swapped over are as followed
M50B25 non vanos turbo
t3/t4 hybrid turbo
2.8 pink injectors
uprated rising rate fuel pressure regulator
lhd turbo tubular manifold with flyover pipe to move the turbo forward
decomp plate x2 oem gaskets
ecu masters piggy back ecu
6 puk padel clutch with m3 flywheel
1.6 drivetrain with welded diff
rear subframe raised 10mm
so here she is sports fans !! (ZO3Y)
got her back home then started work on it almost straight away
running FK coilovers(will be upgraded to hsds soon) with austfab modified hubs for more lock
got myself some shiny rotas
need smaller tyres I know but you get the idea
got some cool skid wheels (car came with a dented door, now replaced)
ripped the old 1.9 engine out
and the wiring loom
painted the engine bay
and that's where I am at the moment
waiting on a new paddle clutch before I put the engine in, il then be fitting the engine and loom ect
then the cage will be welded in and the whole car will be getting painted
il try and keep you all posted
t3/t4 hybrid turbo
2.8 pink injectors
and the wiring loom
