Hi all,
Finally getting some time to utilise some of the new stuff following the updates - first off is how you view this site!
There has been for many years a dark and light variant option called - Dark Zorg and Light Zorg. These themes were from a 3rd party developer and served us well - however we are seeing a few minor display issues with them.
Now within the core functionality is this exact feature which I've enabled. The best bit of this is when using the "Default Style" the forum will look at your devices preference. If you have "dark mode" enabled on your device, you will automatically see the dark variant. Likewise for "light mode".
Let me show you how to set....
At the bottom of the forum you will see two options, the left being your current choice of style. If you do not have "Default Style" selected....
From the popup select "Default Style" if not already.
Once you are on Default Style that's it. When moving between devices the forum will switch between the Dark and Light variants automatically.
If you wish to override this, you can use the round button next to Default Style, which gives you these (System is basically the default)
Correspondingly one set the round icon will change to reflect the current mode being used.
