- Joined
- Feb 18, 2016
- Points
- 231
- Model of Z
- Z3M Imola and Z4 (e89)
Well once these are put on Willow that's it, there is nothing else to do (buy) (well other than fit the new pulleys and belts which are sitting on the bench) Its been a 4 year love affair and a depleting bank balance but she is as good as she can get.
zroadster.org
zroadster.org
zroadster.org
zroadster.org
zroadster.org
#ZedShed - Nodzed's M Roadster gets a suspension overhaul
Had a visit from @Nodzed today to get his new suspension fitted. He arrived with plenty of bits! Spax springs Eibach B8 shocks Front & Rear shock top mounts (including reinforcement plates for the rears) Front drop links A subtle lowering, nothing too extreme as he doesn't want his ///M to...
#ZedShed - Willows new bushes
Had a trip to the HQ on Saturday to get the beam bushes on the ///M replaced (all the other bushes were done 3 years ago). As it turns out the beam bushes were totally gone and the poor old thing was steering on the back end and felt horrid. Beam out, re-bushed and back on the road in 4 hours...
#ZedShed - Z3M Clutch and Gearbox Shift Pins
Over the next two days we’ve taken in @Nodzed stunning Z3M in primer. :D He was complaining of a noisy release bearing and the gearstick sitting to the right when cold both of which are quite common on all Z3’s. All the larger engine Z3’s use the same gearbox, even the M’s. So the first thing...
New LEDs
Just fitted some new LEDs from Horizon LEDs 80w Reds for Brakes and Fogs 5w Reds for tail lights 80w Whites for reversing. to say they are impressively bright is an understatement.
New Discs and Pads
The old discs on the ///M were looking a bit worn so thought it was prudent to replace them all round, so a set of Black Diamond grooved discs (was advised to stay away from the drilled ones this time) and Red Stuff pads fitted today ready for the next week end in the lakes. Some pics of the...
