Before
After
After
Well chuffed Jack, it looks a lot better and seems more planted too.My rears could do with this mod. It looks spot on Eddie
I thought it may cause confusionI got confused initially because the after picture is dirtier then the before one, assumed you'd just washed the car and got the pics in the wrong order
On to business, yes! Everyone should have spacers![]()
I think that may be a bit of a myth.Excuse my ignorance, but don't wheel spacers put unnecessary extra loading on the wheel bearing? I wouldn't feel happy using them except perhaps on a competition car where components don't cover many miles and are checked all the time. I couldn't see any difference between your pictures until you pointed it out.
Then you have 2 lots of bolts to make sure you have tightened correctlyLike it, it was a mod a did a while back -- you might want to try 10mm at the front too!
For the 20mm, I'm surprised you didn't for the 'dual' ones -- ie with one set of bolt to get the spacer on the hub, and another (the normal ones) set of bolts to get the wheel on the spacer (see http://www.dvbcaraudio.co.uk/wheel-spacers-c-752_1042.html ). I also installed steel ones to make sure the load problem @Bumpa mentions doesn't occur. *Personally* I'd be a little bit worried with bolts that long, and they'll take quite a bit of torsion -- but for all I know, it doesn't matter at all?
@Bumpa the spacers do make a hell of a difference to the looks, seriously... Especially from the back I have to say.
See post #4 Jim. When I put these on my Z3 a few years ago the difference was instantly noticeable. Also when I swapped them over to my Z4 too. 40mm. wider track at the back and 28mm at the front on mine.Looks good, stance now looks more appropriate for the wheel arch.
Interested to know if handling is improved, worse or no different?
The fronts already fill the arches so no need for anyLike it, it was a mod a did a while back -- you might want to try 10mm at the front too!
No I don't think so, I've had 20mm spacers on mine for 3 years now and it's been no bother, wheel bearings have been fine on each MOT. I personally think they fill the arches out really well. Big improvement @Eddie ZedderExcuse my ignorance, but don't wheel spacers put unnecessary extra loading on the wheel bearing? I wouldn't feel happy using them except perhaps on a competition car where components don't cover many miles and are checked all the time. I couldn't see any difference between your pictures until you pointed it out.
