Seems complicated, glad I am too poor to have split rims.
Love thatOne wheel in primer.
Thanks yes it clear coatedreally good. is that clear coated?
What are you doing with the inside of the barrels Sean?Got one of the rims painted today, its the finest aluminium I could get my hands on as I didn't want sparkle, I wanted it to be as close to a polished finish as I could get. I will do for me
I have some standard silver for them mateWhat are you doing with the inside of the barrels Sean?
The inner part is going to be Shadow chrome I think as well as the stainless hoops that I have just got.What are you doing with the inside of the barrels Sean?
Sean you might be able to lay a small nut over the top of the broken stud, then using a mig welder fill the Centre with weld to make a new head to aid removal. I use this technique a fair bit and it hasn’t let me down yet.Had a bit of time on the wheels last night and managed to remove 3 of the 5 snapped bolts on one wheel, I have been toying with an idea of how to get enough heat into the snapped studs and came up with an ingenious solution (even though I do say so myself)
We have a spot weld pin puller that we use to put pins on panels so we can pull dents out, it worked perfectly on the studs and a 2 second burst had them glowing bright orange, mole grips did the rest, the problem I have with the other 2 is that they are just 2 short to grab.
Also got one rim stripped ready for etch primer
The problem being that the studs are titaniumSean you might be able to lay a small nut over the top of the broken stud, then using a mig welder fill the Centre with weld to make a new head to aid removal. I use this technique a fair bit and it hasn’t let me down yet.
Should get the centres to powder coaters this week, along with the roll hoops, having them all in dark shadow chromeWatching with interest here mate.
