I found the same when I fitted mine Sean on my Z3, also on my Eunos when I had it too. Ant followed me in my Z3 round a series of bends the day we fitted my boot spoiler on my 4 and he did remark how flat it stayed in the bends. It did have a good susp. kit on it as well though.Yes that it Ant, "much flatter" sums it up a treat, less roll which makes the car much more predictable
I have one identical to this which I'll be fitting this weekend, but I have a query.Never thought I'd fit one of these but really like it now its on, a big thanks to Niall @Nodzed , and donation on the way @GazHyde
Compression I'm thinking, If you are cornering round a right hand bend, the load on the LH front strut tower is being transferred up the strut brace to the RH strut tower, in essence the right hand strut tower will be stopping the LH strut tower from flexing under load and vice versa.Do strut braces work in compression or expansion?
Crikey mate I bet that was scaryOut this morning testing things again and was really impressed until my O/S rear blew out whilst hard cornering, had to check my pants once I got to grips with the car, I was very close to home so limped back, I may need a new 108 once I get it off to check the rim.
Thats the car off the road until I can get a pair of new rears, I have heard great things about Landsail LS388 and the reviews are outstanding, has anyone tried them.
.Compression I'm thinking, If you are cornering round a right hand bend, the load on the LH front strut tower is being transferred up the strut brace to the RH strut tower, in essence the right hand strut tower will be stopping the LH strut tower from flexing under load and vice versa.
(Hmmmm.........Sits back and waits to be proved wrong)
Hmmm, so what is actually happening when no strut brace is fitted?The top mounting of the struts and the angle they sit would indicate its compression.
Removing the slack will benifit both directions as it will just become ridgid.
Mine has no adjustment it bolts tight but others have an extending bolt each end to assist to get the perfect fitment.
Ouch!Out this morning testing things again and was really impressed until my O/S rear blew out whilst hard cornering, had to check my pants once I got to grips with the car, I was very close to home so limped back, I may need a new 108 once I get it off to check the rim.
The Z3 moves around an awful lot, in fact is has the torsional stiffness of a jellyHmmm, so what is actually happening when no strut brace is fitted?
When you load up one wheel in the corner, does the chassis on that side twist, reducing the camber angle of the wheel and strut, therefore moving the loaded strut top outwards as it pivots around the chassis rail. Increasing the distance between the strut tops.
OR
does the camber angle stay constant with the load forcing the entire strut inwards, therefore reducing the distance between the strut tops?
I'll take some pictures as I install to explain the slack better.
@Sean dgood catch!
Also interesting to hear the comments on tyres as they are next on the list to tie in with rims refurb!
I knew my tyres where on their wear limit on the inside edge, particularly the O/S, I was on a cruise last weekend in the Peaks and pushed the Z pretty hard, in fact I even commented to one of the guys that my tyres would be shredded after this run, I'm just pleased I didn't turn off the ACS, I'm comfortable using budget tyres especially these days with all the reviews on line.Wow @Sean d not the sort of thing you hear these days, with regard to tyres, I a great believer in buying the best you can, IMO you cannot beat a premium quality tyre.
The Z3 moves around an awful lot, in fact is has the torsional stiffness of a jelly, that why we love em.
Yoiks Sean, scary stuff. Hopefully after a clean pair of pants you are OK. New tyres to be bedded in before next weekend thenOut this morning testing things again and was really impressed until my O/S rear blew out whilst hard cornering, had to check my pants once I got to grips with the car, I was very close to home so limped back, I may need a new 108 once I get it off to check the rim.
it was iron Bro . . . .
