Stiff Throttle
Smudgemanuk
Bicester, Oxford
2.8l
I own a 98 2.8 TU z3
The throttle feels a lot stiffer than my dads e46, it is both stiff to push down and lags slightly behind when you take your foot off fast
However having the TU engine means my throttle is drive by wire
Any ideas on what may be causing this, and possible fixes, would be much appreciated
Thanks Chris
AntStark
Hampshire
2002 3.0 Sport
2.8 TU are cable operated not electrical (drive by wire)..or is that what you mean. The cables age and corrode internally over time making them sticky. There is a grommet on the pedal end that also disintegrates. You could also clean the throttle body and spring too
What happens with a throttle cable us that over the years the wire inner cable wears slot in the inner plastic liner. This then "grabs" the inner wire as it slides in the slot. Lubrication may help but eventually you will need to replace the complete cable.
Smudgemanuk
Bicester, Oxford
2.8l
2.8 TU are cable operated not electrical (drive by wire)..or is that what you mean. The cables age and corrode internally over time making them sticky. There is a grommet on the pedal end that also disintegrated. You could also clean the throttle body and spring too
Damn that is news to me!
Thanks for correcting me and I will try that later this week
Much appreciated
How tricky is it to replace the full throttle cable?
How I would do it is this. Disconnect the engine end of the cable. T.ie a length of string to the end of the cable. Disconnect the pedal end of the cable and carefully withdraw the cable into the car. When it's all in the car remove the string from the engine end of the cable. Compare the new and old cables to make sure they are the same. Attach the string to the engine end of the new cable and carefully draw it through the bulkhead into the engine bay.
Attach the cable at the pedal and then (after removing the string) at the engine end. Adjust the slack adjuster to remove almost all the free play.
AntStark
Hampshire
2002 3.0 Sport
Not too difficult..it’s a bit fiddly that’s all. Having a spare set of hands to pull the plastic clip through the bulk head really helps when removing the old cable.
Finding a replacement cable at the moment is the difficult bit..they are on back order at BMW. Some cables have a barrel like in the vid, some have a ball end.
The 2.8 tu is a bit of a hybrid engine.
The 2.8 non tu has a throttle cable
The 2.8 tu also has one
The 2.2 and 3.0 are electronic.
The non tu and 2.2 and 3.0 can all have cruise control retrofitted to them
You cannot fit cruise control to a 2.8 tu.
The 2.8 tu was built at a time when Euro 2 was the requirements but the 2.8 tu has a Euro 3 set up with twin cats ( instead of 1) and 4 Lamba sensors pre and post cat instead of 1 the non tu 2.8 has.
But a great engine ( in my opinion best in a pre face-lift bar the m model) i still think my tu drives sharper and sounds better than my non tu which has less than half the mileage .
Stephen.
rmoconnor41
BMW weren't able to provide a date when they could supply a new cable 35411164834.
I thought a RHD cable for a 3 series E36 might fit but unfortunately my old Bowden cable attaches to the throttle body with a ball whereas the 3 series cable has a bar at the end.
Seems to be a lot of LHD cables for sale on E BAY.
AntStark and I did get the cable out and it was fiddly but not that difficult. You can see the bar at the end in these photos.
Smudgemanuk
Bicester, Oxford
2.8l
I found the same thing. I ordered a cable from BMW last night, only for them to say they won't have any for at least 18 months!!
Where did you source your cable from?
Thanks Chris
rmoconnor41
Thanks Chris
[/QUOTEBMW did some investigating when my X3 was in with them and mentioned redesign. But they thought that meant possibly no more cables.
