Had the winters on the 330 swapped out for the summer set that the dealer had in storage this morning. Set off back for home and was just pulling onto the motorway after about half a mile and the tyre monitoring system chimed in. Thought nothing of it as it usually goes off after the wheels are swapped out. A few seconds later a second alert comes up saying tyre pressure warning. Wasn't expecting that, so I put the tyre pressure display up. Considering the fronts should be 2.4bar and the rears 2.6bar, the fronts were reporting 1.7bar and the rears 1.9 ns and 1.6 bar os.
Drove more slowly home that I would normally have done and then checked and re-pressurised them all. Yes - all tyres low but marginally higher than the screen display, probably because the tyres were warmed up by then. Still, putting a tyre on at 60% of its correct setting is not very amusing. Interesting conversation then with the service desk rep. They've just call back and admitted they didn't check the pressures on the summer set!!!
They've offered a free fill-up in compensation when I'm next passing. Am I letting them off lightly with that offer?
Not surprisingly I have much reduced confidence in BMW service if they can't get such a fundamentally basic safety issue right. It isn't hard. They had one job. Mind you, I haven't checked the torque on the wheel nuts yet. Should a tank of fuel restore confidence?
And this is after they gave the key to my car to another customer....
And breath.....
And breath.....
