My in-laws used to as well mate. The tyre game is a very cut-throat business these days and profit margins are very competitive.
Hi Cat, its too cold and dark to go and check, but that date would tie in with the build date of my car. I'm not planning on using the wheel again. I note that there are loads of used examples of these spacesavers for sale on the bay with no mention of their age by the sellers....Evening all, just tried to zoom in on the tyre pictures up above but I can't quite make it out, if you look at your tyres you'll find a date code on them. This particular tyre seems to be 4301, this means the tyre was made in the 43rd week of 2001, like I said I can't quite make it out but if this is correct the tyre is way past it's use-by date (generally reckoned to be about 5 or 6 years). You'll have to have a close look yourself, but this will tell you how old the tyre is.
No worries, bit of a guess but that's what it looks like, similar function to a bump stop in a shock absorber. Regarding the shoes about Eire and NI, you must keep me updated as I'm garbage at remembering these dates. Cheers.Cheers Baz, i'm relieved it has a car related purpose!
I've been following your thread on the restoration of the ///M, top work, hope to see it out on the road or at some of the shows.![]()
Are you sure it was Hermetite.... and not Hammerite...couple of coats of Hermetite ...
Good but not quite, there are two of these that hold the spare wheel in situ under the car, when you push your spare wheel carrier back in and upwards the wheel sits against these stops.To answer the question about below, it looks like a bump stop to protect the rear upper arm slamming against the chassis/body during extreme driving over crests/hills n stuff....
Good man Brian, thanks you. Very polite way of correcting me, I appreciate that. On some other forums I use I'd have been called several different names and told I was useless and should be burned in hell for such an error. Cheers.Good but not quite, there are two of these that hold the spare wheel in situ under the car, when you push your spare wheel carrier back in and upwards the wheel sits against these stops.
