Go and sit in the naughty corner for 30 minutesLooks like a butt plug
Yes, its a myth that the tyre can not be repaired after using the gunk.Do you know if the tyre can be repaired properly after using those?
Essentially yes. This is the kit, except this is branded MINI but it's identical.Is the inflation kit a compressor and goo type?
I've never checked, but I would still use this in preference to the space saver any day.Do you know if the tyre can be repaired properly after using those?
Bullshit Tony, use a steam HP cleaner........Agreed, but it's horrible s*** to clean out and if you were charged a fair amount of labour to do that it probably wouldnt be cost effective though.
Is that part of the kit that goes with the buttplug Gaz?...........Essentially yes. This is the kit, except this is branded MINI but it's identical.
Not many tyre centres will have a steam cleaner Mike, and it's still horrible s***.Bullshit Tony, use a steam HP cleaner........
