Spare wheel carrier - powder coating ??
Brian James
Nr Lincoln UK
1.9 M43 B19
Just removed my spare wheel carrier cage from my 99 1.9l Z3 and thought I might (grit) blast it then powder coat it in order to improve its resistance to rust.
Only snag is there is a black plastic part? or plastic covering?? where the wire clip that holds the carrier temporarily in the boot (before further securing with the hex nut etc) engages.
Question - will powder coating at ca 180 C damage this plastic part / covering ? Has anybody else powder coated their carrier and was it adversely affected by the heat process?
Many thanks in advance for your feedback
Kind Regards
Brian
Z Victor 1
Formerly "Ontiken1"
Ripley,Derbyshire.
E 89 Z4 S drive 23i
I removed the spare wheels and carriers from my Z3 s. They are a waste space as in the event of a puncture there is nowhere to put the offending wheel.
Dakar Z3
Dakar
Sunderland
Z3 2.2 , Z4 Coupe 3.0si Auto
Hello Z Victor 1, Zedonist may have a solution to the dreaded punctured wheel and what do I do now?
Watch this space"……………
Dakar Z3
Dakar
Sunderland
Hello Brian
I’m not sure which plastic piece you mean, I have had my cradle blasted and powder coated, no problem at all, looks great. You do have to replace the sticky backed sponge rubber on the frame however.
Dakar
Brian James
Nr Lincoln UK
1.9 M43 B19
Thanks Dakar - I thought it was made of plastic as it is black coloured and just assumed it was - it is the cone shaped piece that the wire "clips" grab when lifting the wheel carrier into the boot floor. This black cone piece is an integral part of teh captive bolt that the flexi wire is attached to - I hope I'm making myself clear but I guess a piccy will help so will try today
Thanks to others for their comments too - - I guess having "her who must be obeyed at all times" would be happier cradling a dirty punctured tyre than just sitting by the roadside in the pouring rain :) . After 40 years of marriage the poor lass has had to put up with a lot !!!:)
Kind Regards
Brian
Peter1450
Bristol
Z3 3.0
Never really thought about it but as mentioned above the cradle only carries a space saver ,so nowhere to put the punctured standard wheel especially if you have a passenger on board!
Delk
Hemsby Norfolk
Z3 2.8 real widebody
Mine was removed but the misses still has one in her car. Not sure what happened but she lost the whole inner sidewall and the spare saved the day last month.
Delk
Hemsby Norfolk
I keep a can of sealer in my car but it wouldn't have helped with this. While the spare was out I cleaned and painted it as it was showing its age.
I cracked a wheel in the middle of knowhere, my spacesaver got me home.
Brian James
Nr Lincoln UK
1.9 M43 B19
Wow !!! I hope nobody got hurt - as they say " every picture tells a story"
On this forum, recently, but a different thread I asked about tyres as I have just bought a 99 1.9 l Z3. I got some very good feedback so I have purchased a brand new set.
Kind Regards
Brian
p.s. Following the feedback, have now instructed the powder coaters to strip and coat the frame so will show a photo in the New Year when back from the workshop.
MisterP007
German-Italian-British Mix - What could go wrong?
Tunbridge Wells
Kind Regards
Brian
I read "every puncture tells a story" weird the way the brain works!
mrscalex
Just had another spare carrier done this week. They look great. But the process will find out any thin sheet metal.
Brian James
Nr Lincoln UK
1.9 M43 B19
Hi,
Just thought I would feedback so as to close this one but also to pass this experience on to others.
A marked improvement and sooooo glad went this route ....purists now look away as I made it bespoke with the body colour.:):cool:
Did the spare wheel as well so well and truly hung for my sins !!!😊😁
Thanks to everyone who helped me make this decision - really pleased.
Take care
Kind Regards
Brian
Dakar Z3
Dakar
Sunderland
Hi,
Take care
Kind Regards
Brian
Great job
Brian James
Nr Lincoln UK
1.9 M43 B19
Thanks Robert for the info on callipers. I have mine to do so wanted to get a heads up on best approach and it clearly looks like you nailed it !:thumbsup:🙌
Kind Regards
Brian
