How To Guide Source of throttle cables found!
Smudgemanuk
Bicester, Oxford
2.8l TU pre-facelift z3
The throttle cable (pt num 35411164834) on my 2.8 z3 needed replacing.
BMW don't make them anymore so I had to source elsewhere
I found JJ cables on Facebook, based in Banbury, others I know have had great experiences with them
He said he cannot reuse the hook on the pedal end of the cable
So we found a triumph clevis (that JJ has in stock)(pic attached) that goes over the hole where the hook went, and then a pin goes through it
I couldn't use the original gromit so I cut a piece of hose pipe to stop the pin from rattling around. You wouldn't believe how well this fitted
JJ was quite busy, but he did it for a very reasonable price.
So the cable now has a brand new inner and outer, and looks brilliant
Thanks to JJ cables for that
Chris.
AntStark
Hampshire
2002 3.0 Sport
Did they reuse any of the original cable ?
Smudgemanuk
Bicester, Oxford
They only reused the outer mounting parts like, the gromit near the brake servo, and the bit that goes through the firewall
So in summary they only reused the bits they could not recreate as they are BMW special
liebrand
Hey Chris,
Do you happen to have kept any measurements of the cable? E.g. length and wire gauge etc?
Cheers
Jelte
Smudgemanuk
Bicester, Oxford
Here is the final result!!
Very pleased indeed, works like a charm
Instead of the rubber grommet, I used a piece of hosepipe to stop the pin from rattling around, it fits perfectly!
Smudgemanuk
Bicester, Oxford
@liebrand
I could measure diameter of the inner (silver cable) and the outer diameter (black shielding) if that could help you?
Smudgemanuk
Bicester, Oxford
Hmmm
I have just realised, this is the cable I got custom made, so the dimensions may differ a bit to genuine
If those measurements would still be useful to you then, I am happy to go ahead, but be aware it could be slightly different
And, as I forgot to state I can only measure the diameters of the inner and outer, as the cable itself is on the car
Smudgemanuk
Bicester, Oxford
HOW DID YOU MANAGE THAT!!
I paid for one from stevenage bmw about two months ago and they emailed me to say they didn't have any!!
Good for you managing to get one!
