mine sometimes leaks, its very random, like it can really pee down and be fine, then another day you get that daft misty drizzle and it comes in, think it depends on the wind direction and where i park.
Gotcha, thanks a lot Brian.Been shopping @Grumpy here'e a pic of the grub screw. Undo the rrof catches and tip the front up and the grubscrew is in the black bit of the hook. When the catch is shut it is against the roof.
2.5mm allen keyGotcha, thanks a lot Brian.
@Grumpy Just a quick warning, the grub screws if not undone for a while can seize solid, I rounded the Allen head of one of mine on the 2.8, bugger of a job to drill out. I would undo the roof the day before and get some WD40 down the hook thread and around the grub screw, wish I had had the foresight to do this, did it on the other side and it came undone a treat.Thanks Brian. I'll do that when it stops, if it stops! I've just had a look and found the grub screws.
Ha Ha scrap that then, didn't read on see you've done it@Grumpy Just a quick warning, the grub screws if not undone for a while can seize solid, I rounded the Allen head of one of mine on the 2.8, b***** of a job to drill out. I would undo the roof the day before and get some WD40 down the hook thread and around the grub screw, wish I had had the foresight to do this, did it on the other side and it came undone a treat.
Thank's for the warning nod. I did it as I'd posted and they did come undo fine. Can see what your saying tho.@Grumpy Just a quick warning, the grub screws if not undone for a while can seize solid, I rounded the Allen head of one of mine on the 2.8, b***** of a job to drill out. I would undo the roof the day before and get some WD40 down the hook thread and around the grub screw, wish I had had the foresight to do this, did it on the other side and it came undone a treat.
Morning all! Just gone out to Reggie to do something and the passenger seat looks like a swimming pool. It may have been leaking a long time but as I don't usually run him in wet weather I wouldn't know. It looks to be coming in from across the top of the window.
Is there any adjustments that can be made or any quick fix or am I doomed to the leaky roof from the pits of hell!
Thanks
Grumps.
