Hi All,
I’m hoping someone has experienced this before and can offer some advice.
I’ve just reassembled the car after having the manifold out, replacing the secondary DISA, CVV and stripping/cleaning the starter motor. The repair was spread over period of 2 weeks, so battery was disconnected for a while.
I went to start the car after reassembly and it began revving on its own, and the accelerator pedal was non-responsive - I went and checked and of course I’d forgot to reconnect the throttle body connector!
Went to start the engine again and on top of the car turning over a long time before firing up, I had these three lights show up:
- Power steering (EPS), ABS, Traction and tyre warning.
Did some research and it was suggested that a weak battery can cause these to fail, so plugged in my CTEK battery reconditioned overnight. Tried again this morning and I still have the same problem.
What I’m puzzled about is that I wasn’t working anywhere near the areas that are throwing out warnings.
Does anyone know what has happened? Have I tripped something from not reconnecting the throttle body or leaving the battery disconnected for too long?
Any help would be greatly appreciated!
Thanks,
David
Thanks,
David
