surely the 'electric valve' behind the cylinder head is the solenoid valve which cuts off hot water to the heater . . .
It is blanked at the manifold mateYes it is getting data only to open n close. If anything check the blank hasn't fallen off. Or remove it and blank it at the manifold as discussed above.
Double check it is. If that’s the case the valve will just be opening n shutting to satisfy the DME.It is blanked at the manifold mate![]()
@Lee It’s those 3 (1 big, 2 little) right hand rear side of the inlet manifold yeah?. Replaced all of those as they were perished. CheersDouble check it is. If that’s the case the valve will just be opening n shutting to satisfy the DME.
