rmoconnor41
- Joined
- May 25, 2021
- Points
- 68
- Model of Z
- 2.8
Sold
Check the push rod bolts are torqued up. I only cracked mine loose to check I was going to be able to undo them, obviously didn't tighten them up enough and then had the same symptoms you described
Firstly the car has had lots of expert work at the rear end including beam bushes diff bush shocks and tank straps. Exhaust is not loose. Basically rear end is sound.
When I am forced to drive with the top up the car makes quite a loud clunking noise on uneven surfaces. Don’t hear anything with roof down.
I am not carrying a spare or the plastic tray and everything including the battery is secure in the boot.
Where else to check? Thanks
I will Google that as the electric roof operates well.Could be the top mounts of rear shocks. Another strange one, but fits with the roof up is the strut that is meant to make raising and lowering the roof easier might have become separated like mine. That can rattle about. It’s on the LHS near the pivot point of the roof mechanism.
Probably won’t be that if you have electric roof and it works well.I will Google that as the electric roof operates well.
SoldProbably won’t be that if you have electric roof and it works well.
Yes, I know what you mean. On my car, the exhaust back box is very close to the anti roll bar for some reason and if they touch, you hear it in the cabin when the roof is up. Roof down you don’t hear anything.Thanks. Very hard to pin down. Anywhere underneath from literally under seat to end of exhaust which is a very short distance on a Zed
