Soft top problems
PHILIP BAXTER
Cardiff
Z3 3.0i Roadster
Hi all. I have been experiencing problems with my electric soft top. 60% of the time, it works straight away with no fuss, but the other 40% of the time it won't move. It doesn't make any weird noises. Some days it takes numerous attempts to get it going. Is it likely to be the micro switch? Anyone else had this?
Cheers Phil.
It may be the switch or the wire that feeds from it
I think its an earth that completes when the roof is lifted and switch activated.
Loss would result in no action.
Does the pump carry a fluid? If so low level would stop it working.
Mine had a bad switch, in my car (USA Version Left hand Drive) there is a micro-switch switch just over your left ear in the top mechanism. Mine was bad and prevented the top from moving. You can look in the electrical section of your manual for the function of the switch, I would tell you but I don't remember off hand.
Just beat me to that conclusion Pete. First basic check.
brake pedal switch is a regular issue. When the roof doesn't work see if you can see the brake lights come on? back up against a wall or anything that will light up. No brake lights means no power to roof.
Dead easy to prove / rule out
Hi @gookah & @t-tony, just been out to the garage. The brake lights were working, and so was the hood.
I had exactly this problem and it was the brake light switch. It also made the cruise control as intermittent as the roof... Not complicated to change just a bit awkward to do.
Spot on Pete:thumbsup:
