They can but its a lot easier with the wheels off the carI just wondered can the liners be taken off with the wheels still on the car.
You may get the rear one out but not front due to securing bolts behind wheel and size of liner - it's a pig wrestling the liners out/back-in with wheels off - can't see why you would want to try with them on. A few photos which show what you have to get at.I just wondered can the liners be taken off with the wheels still on the car.
I'v got to say thisYou may get the rear one out but not front due to securing bolts behind wheel and size of liner - it's a pig wrestling the liners out/back-in with wheels off - can't see why you would want to try with them on. A few photos which show what you have to get at.View attachment 74861View attachment 74865
Well they were 5 years ago when that photo was taken but like me the gloss has long since worn off -I'v got to say this
Your wheel arches are ridiculously shiny![]()
No minions -it's the price the co-pilot has to pay in order to drive it.Have these been wheel bays been steam cleaned or to you employ a truck load of minions to get underneath and give them a wash and polish every time it’s used???![]()
You mean.........You mean you let someone else drive your Z3??....No minions -it's the price the co-pilot has to pay in order to drive it.![]()
Well only back from the pub...................You mean.........You mean you let someone else drive your Z3??....![]()
@Nodzed can you tell me if you just drilled a hole and put a selftapper in, or fitted a plastic nut and screwed a self tapper into that. I had one snap on me and not sure the best way to repair.As @Alin S says not difficult, just take your time removing the trim off so as not to snap any clips, the biggest pain I found both times was getting the rear liners out. Also on the rear of the underside of the front liners there are two plastic nuts each side with metal inserts that fix onto very small studs, these easily snap off as I found out doing the first one (all four that I then had to drill out and fit self tappers to, probably better in the long run but a pain in the rectum), 2nd time around I sprayed a week before with WD40 and again every couple of days, these came off OK
