- Joined
- Dec 3, 2018
- Points
- 95
- Location
- The English Riviera - Torquay
- Model of Z
- 2.2 sport Individual Estoril
SWMBO's Broomstick conked out a bit yesterday. I thought I had cured the rough idle and stalling a while ago! I replaced the inlet hoses and the cam cover gasket, the pipes were perished and a little split, and the rubber gasket had mummified, also I discovered the little vacuum hose was rotten that leads to the fuel filter, all was well. But not now. It has similar symptoms.
I plugged it into my cheap & nasty handset, it came up with P0344, so, I have duly ordered a pair of cam position sensors. It appears these, when faulty, give similar symptoms to the vacuum leaks. I'm not just replacing one, the other will be the same age, and I can do without the earache.
While I still had it, (this poor car hardly ever stands still), I decided to change the fuel filter, not knowing how old it was, it was on the to-do list, and the filter was here waiting. This was straight forward, barring the unleaded shampoo, (definitely no nit's now!). But, the little vacuum pipe onto it was rotten and split, so this is also replaced, I managed to re-use the little brass restrictor, super gluing it into one section of pipe. All the jubilee clips are replaced, just because I had some. She's back out and about in it, she says it isn't as bad, (filter & pipe?) I'll keep you posted when the sensors arrive.
