Well done for getting as far as you have.
Thank you mate! That's really helpful info and encouraging to know others have managed to overcome this. So if I get the metal clamp out the way, I'll be able to see enough of the screw to get grips on it? Seen some special Japanese screw removal pliers that seem worth a shot if I can create clearance around the screw head (https://www.amazon.co.uk/Gripping-Extractors-non-slip-Engineer-neji-saurus/dp/B001D7KU7W).With me, those bloody screws have one chance with a screwdriver. After that, I just bend and break the steel clamp and then wind the screw in and out with Molegrips and WD40.
It's worth belting the end of the screwdriver first to try and shock the screw. Sometimes it works!
It's also worth removing the clamps, popping the brake/fuel lines out of the plastic bracket and giving them a clean up and some grease. I did this on my 1989 7 Series in 2004 and it still has all the original pipes.
Yup.Do you bend back and forth along the same spot until it fatigues
Cheers mate, feeling a bit more optimistic nowYup.
Yes, that will work fine. May be a little time consuming but that's all. Hope it keeps dry for you.No activity yesterday due to inclement weather so taken today off work to attempt brake bleeding.
@t-tony Can I run the following past you pls. I bought a syringe to syphon off all the old brake fluid from the reservoir. Could I use the same syringe to bleed the brakes? In my head, the steps are:
1. Syringe old red fluid out of reservoir, top up with new clear Comma Dot 4
2. Attach syringe to bleed screw with hose
3. Crack bleed screw (1/4 turn)
4. Slowly draw fluid out until red is replaced with clear and no bubbles in hose
5. Tighten bleed nipple, move onto next caliper
If I need to empty the syringe, tighten bleed screw, empty and then go from step 2 again. This should work from what I understand of the process? It would be quicker than gravity (keen to book MOT) and also doesn't involve pumping the pedal
