jedwards921
- Joined
- Feb 3, 2020
- Points
- 12
I'm working with a 98 Z3 with the 2.8 engine. I've tried 2 different scan tools without any luck. Yes, I'm using the 20 pin connector under the hood. Yes, both units are setup for BMW and have the latest updates installed. First, I tried the Creator C310. It seemed to do everything I wanted it to do, but it wouldn't communicate and read any part of the ABS system which it should. Next, I tried the Foxwell NT310. Same results, if not worse than what the C310 gave me.
One thing I noticed while working with the NT310 is that in the screen where you can manually select the vehicle you are working with, the oldest Z3/M52 combination listed is 3/1998. My car has a build date of 11/1997. Did something happen during these 3 months that is causing these scan tools to not work with this vehicle?
I found a couple of mentions about this specific issue with pre-facelift cars via search but haven't seen a good solution yet. Any ideas?
