Thanks Ant,how long should I leave the battery disconnected before unplugging the air bag wires ?Yeah two at the back and you'll have another 4 to swap over your slip ring and a white plastic clip.
Steve
Disconnect the battery (good advice from @Mint ), remove the lower steering column cover 1 x posy screw, and un-clip to separate the wiring connector, 2x torx screws on the rear of the wheel holding the air bag on and I think a 17mm socket for the wheel nut .... place the air bag metal side down just in case it goes off, wont fly into the air thenThere's just two screws at the rear of the wheel retaining the air bag assembly if I remember right @NODZED ?
Steve
Yeah I had to do that as the connectors were different, easy enough though.Yeah two at the back and you'll have another 4 to swap over your slip ring and a white plastic clip.
If the wheels exchange it will be completly bare at least mine was when it arrived had to swap all bits over.Yeah I had to do that as the connectors were different, easy enough though.
Oh yes and it's still shinyColumn nut should be 16mm I think. But you have your shiny new socket set anyway don't you Steve.
Bugger does this mean weve got to change yours againMy steering wheel is on its way home
Mine is an exchange one Niall,so what else did you have to swap over ?If the wheels exchange it will be completly bare at least mine was when it arrived had to swap all bits over.
The slip ring and the white clip 4 small torx screws.Mine is an exchange one Niall,so what else did you have to swap over ?
Steve
I sent a spare one I got off Spurs fan as I wanted to keep my original, but the connectors were different so I had to swap them, but all you will have to do is remove the 4 small torx and swap your ring gear off your wheel onto the referbed one, its easy as mate takes 5 minutes.Mine is an exchange one Niall,so what else did you have to swap over ?
Steve
In time mate but not just now as I haven't got round to ordering the dye for the plastics either side of the airbag.b***** does this mean weve got to change yours again![]()
I've just received a text message from Parcelforce to tell me my steering wheel will be delivered today
It's like Christmas but better
Very nice mate
