Royal Steering Wheels
Antm72
South Yorkshire
I am mate,quite chuffed and looking forward to driving it tomorrow :) It feels really nice. Thanks again Ant for the advice on swapping them over.
Steve
No problems its quite easy when you get stuck in ...looking forward to the pics of the DRL's after tomorrows fit :thumbsup:
Steve
You just wait till I get my oily hands all over it mate.;)=))
Bozzy
Long Eaton.
As some of you fellow zedders know I recently made a blunder when fitting my new steering wheel.
Damaged the slip ring assembly on the back of the wheel in haste to beat the rain :rolleyes:
The wire with the copper strips in it has ripped out of the connector block :meh:.
But tonight I got a replacement one from @Synclare ,thanks Adrian :thumbsup: .
Very convenient as he's only a few junctions down the M1 from me :).
So new one fitted,reset gadget applied.....no more air bag light.....phew :D
Also thanks to @spurs fan in a coupe who came up trumps and has sent me one in the post as I wasn't sure if the one from Adrian would suit.
Steve
Low Rider
Steve
Great news Steve. Glad your sorted mate
Bozzy
Long Eaton.
Glad your sorted for your trip Steve :thumbsup:
Thanks mate I am quite relieved it's sorted and the car has a working air bag again :).
I know where I went wrong......not listening properly to you and everyone else :rolleyes:......i didn't unplug the two connectors under the steering column so when I pulled the wheel forward it unraveled the copper tape strip.
Must have put it back together completely wrong and the rest is history :whistle:.
Steve
They're not something that's easy to undo once they've unraveled mate.
Redline
Nuneaton
E89 20i msport
How long would it take you to get to Nottingham/Derby ?
Steve
It's about 200 years back in time Steve :bag:
About 90 minutes up the M40 then off onto A38 I would have thought.
Well it finally got done, as 2 members know as they had a sneak preview. I got my wheel back from Jack at Royal's on Friday and, having got the extra lighting cable from Soper's on Wednesday, Saturday afternoon was fitting time.
Firstly I made myself a tool to unclip the airbag from the steering wheel ( what was wrong with using 2 screws?) It consists simply of a short length of "Steel" brake pipe, I salvaged a bit from the bin at work. All you need to do is cut/file a groove in the end as you need to push two clips back to release the airbag from the wheel. I fitted a piece of rubber tubing to the end as after several attempts your hand gets sore, I had a second wheel to practice on.
The tool ...
Here's how it works,
After removing the battery earth lead you need to wait a couple of minutes before removing the airbag.Once the airbag is off you need to disconnect the black and green electrical connectors and place the airbag on one side out of harms way. Now the airbag is off you need to unplug the wiring to the squib (slip ring) Undo the centre bolt 16mm and lift the wheel off the column. Before doing anything else it's a good idea to put a piece of tape across the squib and top of the column to stop the squib turning. MOST IMPORTANT!
Observe the mark on the steering column which you align your wheel with when refitting.
In the next picture you can see the main airbag wiring connector at the centre top of the squib and to the right of that is a white plug which carries the audio control wiring.
At this point I had to fit the extra cable from below the column into the light switch multi-plug to illuminate the MF switches. After which it's time to fit the steering wheel. If, like me, you need to fit the extra cable you will need to remove the clocks, just make sure when you refit them that you plug in the connection properly or you may have to remove them again.;)
Lining up the marks.
Centre bolt fitted and tightened, just requires the airbag to be connected and clipped back on the the steering wheel, a little bit fiddly but when it snaps on you know.
The finished article, well pleased with the outcome of this job.:thumbsup:
I'm almost looking forward to going to work tomorrow!;)
Thank you mate, I'm well chuffed.:thumbsup:
I bet it looks very nice and multifunction too a great upgrade/mod and tomorrows drive will be a great experience .Worth every penny...:thumbsup:
:) So says a fellow Z owner ................... =)) Having said that Shirl thinks it looks nice and it has one thing that is missing from her old oil burner:thumbsup: But I still don't want to go to work Ant.:(
Low Rider
Looking very smart Tony.
I got to use my steering wheel for the first time today and it feels just great.
It could be just my but my car feels it drives better
