Hi. Can someone please advise whether the roof motor problems I read about on Z4s were corrected after a certain time. I.e. Fault corrected on all cars after 2005. Thanks. John.
Thinking to do the same, scared by all this stories of dead motor. Did you did relocation yourself or got a specialist?Luckily mines in good order but I had it relocated as a precaution,
M
Took most of the bits off myself, but got a chap just south of Durham to finish it,Thinking to do the same, scared by all this stories of dead motor. Did you did relocation yourself or got a specialist?
I think I've worked out how to tell (or at least giving an indication) if the drains are blocked without dismantling anything. When washing the car (or if it's raining hard) water runs off the roof and down the gaps between the roof and bodywork. Under the car you see a definite stream of water draining out if the drain isn't blocked. Tell us if you see the same.If you clear out the drains for the side"pod(s)" where the motor is mounted you should at least lessen the chances of the motor failing from what I have read.
Quite far from my location though... But maybe one day i'll drive there to get it relocated.Took most of the bits off myself, but got a chap just south of Durham to finish it,
But tbh he only charges £80. To move it to the boot, an at that price it aint worth fookin about ,
M
You sure it's not draining through the holes in the floor @Redline, only kidding, never noticed it on mine, but then the motor failed on that and I had to have it replaced. Thats how I know How to prevent it from happening.I think I've worked out how to tell (or at least giving an indication) if the drains are blocked without dismantling anything. When washing the car (or if it's raining hard) water runs off the roof and down the gaps between the roof and bodywork. Under the car you see a definite stream of water draining out if the drain isn't blocked. Tell us if you see the same.
I know it's a big problem even on cars that are supposed to have sealed motors. The draining water is quite distinctive when I've seen it, but not definitive proof that the drains aren't blocked. Am keeping my fingers crossed.You sure it's not draining through the holes in the floor @Redline, only kidding, never noticed it on mine, but then the motor failed on that and I had to have it replaced. Thats how I know How to prevent it from happening.
Mike
Ahoy there Capt. Pugwash. I'm going to check the drains on mine when I wash it Ian, you're probably onto something here I reckon.I know it's a big problem even on cars that are supposed to have sealed motors. The draining water is quite distinctive when I've seen it, but not definitive proof that the drains aren't blocked. Am keeping my fingers crossed.
Maybe fitting a bilge pump should be considered
