I honestly don't know mate, as you'll have seen I fitted the "Style" type bar and had to remove the outer turrets where mine still fit in the factory holes/sleeves. That's why I'm not too sure whether a wind deflector can still fit in front of roll hoops or not. Obviously I've lost the use of my centre storage bin but can still use the small forwards facing one. To know for sure if your car has the mounting bolt holes I'm guessing you will need to remove the centre bin as in the pictures that Mike kindly posted, unless anyone know differently?I'd thought that with the plastics @t-tony but mine is a pretty bog standard colour so wouldn't have thought it'll be to much if a problem. Is there any easy way to found if I have the chassis holes without stripping everything down?
