So, I did about ~450 miles with the Z this week-end... I had removed the hard top since I knew I'd have dry weather!
Drove to wales (night drive) on thursday from Maidenhead; I was a little anxious as it's the first night drive I do with it, however it did go very well in the end. I averaged 32mpg too, pretty amazing.
One thing I used that I now swear by is yellow glasses. part of my anxiety with night driving in the Z is the low position -- *very* car you meet will try to blind you. I use these glasses for shooting, but I know they are recommended for night driving as well -- I tried them, and wow, amazing -- didn't get blinded at all; it takes a little while to get used to, but what a discovery...
Here's the ones I used: https://www.amazon.co.uk/gp/product/B076Z7NQN8/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1 £18 ;-)
Anyway, following day was top DOWN all the way. Started at -3C, glorious weather, and a nice Z to drive around, so I had an amazing time.
So, things I've discovered driving top down in cold weather:
+ There is a bit of a turbulence just over your left shoulder. So you need a hat, and a scarf of some sort. I wonder if the plex screen is better than the mesh one?
+ You also need gloves. not big ones, but you need them as there is sometime turbulences as well sometimes.
+ Other than that I was driving in a small jumper, and I was very comfy.
+ Heater works very well, BUT it's not linear, it's proportional to the driving style (!). If you pooter about, the engine doesn't have a lot of heat to spare, and you get a bit chilly... However if you slam it for a little while, you can get very toasty instead!
Lucky that I rarely pooter about
I did mostly A roads, only did the bare minimum motorway. On A road, it's delicious. On the mway, it's a bit loud, but again, quite comfy. Way back I also did 32.1mpg, which is excellent since I was definitely enjoying the drive.
I do have a 'new' noise tho, I suspect one of the bushes on the back axle has reached it's EOL -- I'll have to see the Zedsheds experts to know which ones it might be. I know it's not the diff mount, as it's been welded (and the weld are intact). It doesn't sound 'critical' tho...
Gratuitous pic:
Gratuitous pic:
