- Joined
- Apr 15, 2018
- Points
- 19
- Model of Z
- 1.9L Z3
I was driving the other day (after not driving for awhile) and the 1996 Z3 was going great. When I got home I put the car in neutral to open the garage door and noticed that the revs dropped from the usual ~800RPM to much lower and the car almost stalled. The revs then picked back up to ~1000RPM before dropping back to the usual idle 800. It happened about three times while I was watching it that day.
I have driven since and it doesn't seem to happen at traffic lights or anywhere else. I managed to get it to happen one more time in the garage. The engine was warm and idling for half an hour to be able to see it happen.
I connected a code reader and got a DME 6C fault as well as a low battery fault which I cleared and now there are no faults.
I monitored the signals from the engine over OBDII and nothing stands out as strange. I have a 0.21ms multiplicative mixture adaption which seems right. The revs do fluctuate a fair bit around 800RPM with a plus or minus of 50 or so when idle, but I don't think I could tell without the code reader telling me.
Any ideas what would cause the occasional drop in the idle revs or how to diagnose what it would be?
Right now the only idea I have is to try to clean out the idle regulating valve and check for leaks in the air intake pipes.
