Replacing the original sub in the oem enclosure
Keith_Thompson
Houston, Texas
Roadster
Replacing the original subwoofer in the oem enclosure and noticed the padding inside the sub box. Should I remove the padding or leave it for best results?
MattInSV
It’s there to help acoustically deaden the enclosure and minimize internal reflections. If it’s still in good condition I’d leave it alone, but make sure it isn’t affecting the free travel of the speaker cone.
I actually took the whole sub assembly out and mounted a 6.5” dual voicecoil sub vertically to a couple of sandwiched pieces of 1/2” MDF, and I’m hoping to create a fiberglass enclosure that will bring out another 6.5” passive radiator facing directly forward through the existing grille. We’ll see how that goes, but it already sounds pretty good, even with no enclosure other than the (very leaky) plastic cavity
elky
Copenhagen, Denmark
2001 Z3 3.0i Roadster
Last week my sub blew and I am thinking of replacing/upgrading my OEM subwoofer but I want to keep the stock esthetic and the center grill.
Has anyone got any ideas? On Facebook club, a guy proposed the Memphis Audio PRX624 that he manged to fit with only a bit of edge grinding in the stock enclosure, but that sub seems to be in backorder and mainly for the US market 🤔
Found this Amazon.com: Skar Audio EVL-65 D2 6.5" 400 Watt Max Power Dual 2 Ohm Car Subwoofer : Electronics which might fit but I am not too sure...
elky
Copenhagen, Denmark
elky
Copenhagen, Denmark
ExMX5owner
Moderator
Staff member
Australian Zeds
Queensland, Australia
How do I get into the enclosure? Thanks…
If you cant find your 2 x 2ohm driver, you can remove the drone cone assuming its not HK, that one is ported. and fit a second driver where the drone cone was, out of phase with the other, both 4 ohm, get a bit of punch that way..
Rodders67
Indy
Z3M
Literally cannot see how to open what I thought was storage box speaker cabinet… youtube videos are bunch of dudes cutting and removing pieces… they’re mostly morons putting in 8” boxes.
ExMX5owner
Moderator
Staff member
Australian Zeds
Mine was broken when I got it, everything was rebuilt but the evidence suggested it originally just popped off, I assume your talking about the cover...
ExMX5owner
Moderator
Staff member
Australian Zeds
Yessir… the cover seems to have secret
Yes mine was broken and glued on, but as I mentioned, it seemed from the evidence that it basically clips on. But if I am right and I think I am, the thing is likely very brittle as the remains of mine was..hopefully someone else here can confirm my assumption..
Rodders67
Indy
Z3M
I have made several attempts to get the posts to let go. I have three different trim tools and can feel where posts go into the metal crossbar. I have tried to pry from below posts and from above the plastic ring on the post… no luck. I have put two pry tools in to pry against each other like a spreader tool… also it defies me.
Anybody got technique or tool that might release barbs…?
Rodders67
Indy
Z3M
I have solved part 1. The barbs can be relaxed with 1/4 socket from behind the speaker cover. Once you get left (driver side) disengagement permits access to the other pin on right side with flat style pliers.
i cannot get back tabs to release… anyone have a close up view to share?
ExMX5owner
Moderator
Staff member
Australian Zeds
As I thought, clips on.. I guess this is why all my clips were broken off, somebody did not have the patience you do. have you seen this..
View: https://www.youtube.com/watch?v=R_O89MZVfGg
ExMX5owner
Moderator
Staff member
Australian Zeds
I didnt break this one but maybe the image helps @Rodders67 , you can see what happens if you force it...rear passenger tab hole is broken off..
