Iceman
- Joined
- Mar 17, 2016
- Points
- 24
Hello everyone.
I have a 1999 Z3 2.8 which broke a rear spring recently and a shard of it flicked off and cut one of the rubber ends to the fuel pipes leading up to the tank. Bit annoying really!!!
Anyway, I changed the springs but didn't notice this until a few weeks later as it is only really an issue when the engine is running and I haven't driven it much. Anyway, these fuel lines appear to have a swaged on rubber section at each end of a more rigid walled pipe.
My question is firstly, is this swaged on end an essential feature or can I run a long piece of flexible fuel pipe as an alternative? I had a look on the OEM lists and it appears if you want to buy a BMW part you have to buy a full set of tank pipes for $$$.
Does anyone have any advice or view on this? This would be much appreciated. Thanks
