About one an hour I'd guess! Tony makes a mean old brew!
And then there's the one when you arrive and one before you leave.....About one an hour I'd guess! Tony makes a mean old brew!
Plenty of water in Yarmouth. It's by the coast!You've not had a proper cuppa till you come to Scotland. When I go to great Yarmouth on holiday I take water with me to make tea![]()
Cheeky git lol!!!Brilliant job guys, great thread. Good to hear Reggie is fixed. Shame about the photos Dave.![]()
Can't wait Bill. I'm getting a little excited I must admit!Good to know Reggie is now well and truly on his way to a full recovery. Like owner like car Dave. I suppose you are Looking forward to testing him out in Europe now then. Great job lads
I meant the lack of them due to your phone going t*ts upCheeky git lol!!!
I know you did Dave!I meant the lack of them due to your phone going t*ts up![]()
Is your car fixed now @Tracy Dee?
AndyHi @hard top did a battery test it was 12.38 when sitting, with the alternator charging at 14.6, the battery went up to 12.63.Then did a parasitic test and 0.12 - 0.14, I did this on mine and it is 0.19, with no battery issues.
So I was wondering if the problem is the starter motor solenoid or the starter sticking or failing to properly engage, the car is fine if used a couple of times week. This usually has the starter just clicking, possibly then draining the battery if the solenoid contacts are are sticking closed.
I have no idea how I can test a temperamental starter motor, did say if it happens again give mw a shout and I can re-test the battery see what load is being drawn.
Any ideas would be good chaps.
andy
Andy
Stick full fan on full chat and your head lights on and test to see what the alternator is kicking out then, it may not be charging properly?
You need to load the alternator with as much. As Andy said, headlights, front and rear fog lights , hazards, fan on max, wipers on fast everything you can. Then increase the engine idle speed to 1500-2000 rpm and make sure the charge rate increases, 13.8 - 14.0 V is good . The main thing you need is the pick in charge rate when engine speed. Is increased however small, if you don't get that it's not charging enough.
