Rear window trim unstuck
TraceyP
Hi all, the rubber/plastic trim on the outside of my rear window has come loose and the edge of the canvas has come untucked, i've tried glue and double sided tape but as soon as I put the roof down and up again it comes loose. Any tips or tricks I'm missing? The rear window itself is fine so dont really want to replace it! Thankyou
NZ00Z3
New Zealand Zeds
Timaru, New Zealand
3.0L, 2.8L, 2.0L Z3 Roadsters
The rubber trim is attached to the window. If the rubber trim is coming off, then the usual way of fixing it is to fit a new window.
handsomejackuk
Australian Zeds
t
I wonder if there's any other thicker trim that could be used and clipped over the canvas
Steve Medlock
Tenterden, Kent
If its just the canvas edge coming adrift, I usually put some black silicone underneath and tuck it back in.
TraceyP
It's mainly that but also the seal coming away from the window, will try some extra strong double sided tape on that and then silicone for the canvas - thankyou!
NJBoyce
Could try gluing using hot glue gun for fixing seal and evo stick spray contact adhesive on canvas
