Anyone have a suggestion on where to buy reasonably priced rear wheel speed sensors for a year 2000 2 litre Z3, can't believe they're around 50 quid each!!
The ABS light is on, connecting to a MaxySis diagnostic scanner via Bluetooth and driving the car shows no output from either rear wheel. I've taken the connectors apart to clean and reconnect but no difference, As usual they are stuck in to the hub. Need to eliminate them to see if there is then a fault in the ABS module
