Rear Wheel Spacers?
Sean d
Lincolnshire
It depends if you have 4 fronts or 4 rear as to what spacer you fit, I think
Craig Machin
Hi, I have not done anything about spacing as yet as I shall probably look at lowering the car by 30 mm first
DaveP
Reading
Z3 2.2 Kobra rebody (see pic)
I have two sets of TPI 12mm spacers if needed. Having a garage clear out currently. So will offer these in the For Sale pages soon anyway.
Dave
Sean d
Lincolnshire
Dave
I'll have a set of them pal, pm price please
Lenny b
Dave
Dave can you pm me about the other set please. Thanks
DaveP
Reading
Pms on their way gents.
I dont have longer bolts unfortunately as when i bought the set of four they came off an M5 which had bolts with different thread :(
They are 5x120 hub centruc with 72.6 centres (fit Z3)
Dave
Sean d
Lincolnshire
Dave
Oh, what length bolts will one need
12mm longer then standard I guess :D
DaveP
Reading
Exactly :) i think.
Given the fact i bought the wrong bolts with the set originally, I am going to defer to someone's better knowledge on the std length of 27mm(?). One thing i noticed once when working at another persons place who had a box of spare wheel bolts is that if you go too long (only by a couple - few mm) is the bolt can rub on the wheel inside somewhere.
I picked up the wrong bolt one day and couldn't figure out why i had a sound coming from a wheel as it turned.
So even with my little experience it shows that going correct bolt length is key.
That said a trained eye will jumo on this thread and i welcome the advice.
Dave
Too long a bolt will catch on the back plate. How do I know? I know because when I fitted my winter wheels the front spacer stuck to the summer wheel, and when I put the bolts in and spun the wheel before lowering (a habit I have) I heard it.
I can whip one out and measure it tomorrow if needed?
Sean d
Lincolnshire
Exactly :) i think.
Dave
Standard thread length is 26 mm I have just ordered some 40mm
https://www.ebay.co.uk/itm/M12x1-5-...e=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
@Lenny b you will also need some
DaveP
Reading
Thanks @t-tony
Ahh back plate. I wasnt sure what it hit but did confuse the heck out of me.
Wasnt until i replaced the wheel bolts one at a time that i figured out my mistake.
This mean longer lockers are needed too i guess. When i bought the whole TPI set of four it came with locking bolts. Wrong bl@@dy thread pattern though :(
Dave
Thanks @t-tony
Dave
To be honest, unless you regularly leave your car in a place where theft is likely (I never do) then lock nuts are a waste of time Dave.
DaveP
Reading
Given the amount of universal un-locking kits all over fleaBay I imagine you are right on that front Tony. I don’t have lockers on my DD and don’t give that a thought.
