- Joined
- Aug 2, 2023
- Points
- 66
Hi all - UK spec 1998 Z3 with twin front and rear fog lamps, but the rears are on permanently. The switch works on the front fogs, but the rear lamp button to the right sort-of moves in and out but makes no difference. I'm assuming it's broken due to the way it moves and needs replaced. I can't get at the switch due to the large trim panel below - are these simply press-fit pins holding it on? I don't want to be brutal and break something in error. Two here and one on the outer side. I also assume the fog lamp switch itself simply presses out from behind? All help and advice welcome.
