Hi peeps has anyone any ideas where the search for a planted feel to my rear end ( excuse the pun) mot two weeks ago nothing noted etc
Regards Gary
Regards Gary
They're not leaking but they are 23 years oldA leaking rear damper causes rear steer, even a tiny amount of rear steer makes the handling interesting to say the least.
Yea I think that I'd better get some ordered, any particular type I should look at ?I think you've answered your own question there. When you remove these, which are likely the original shockers, they will have no damping left in them. Bear in mind also that the fronts will likely be the same too.
ps. Is that something you can do yourself Gary?
Yes I'm reasonably competent it's the cost of the shockers thats the shock !If you're wanting a "standard" type ride Sachs are OEM but a lot of people use Monroe. Is this something you can do for yourself ? Reason I ask is that you're only an hours ride from here, ZedShed (Midlands), if you need some help.
That's great pal I will no doubt be calling you in the future asking for your helpThat‘s good, but the offer stands. I have spring a compressor and a lifetime of mechanics tools, a lift and a pit free to use.
Had it up in the air the other day they looked ok but you never know but looks a pig of a jobmaybe the subframe bushes.
Springs are ok I checkedA broken rear spring is not uncommon.
The newness has probably worn off thenThey're not leaking but they are 23 years old
