Hey I posted to bimmerforums but did not get any responses. I swapped a 6-speed from an e46 m3 into my z3 coupe. It rattles when it is in neutral with the clutch engaged (clutch pedal out) and stops rattling when the clutch is disengaged (clutch pedal in). I noticed this rattle only happens when the car warms up. I have a self centering shifter and I notice the tone of the rattle changes no matter which direction I push it. This is a link to the clutch I bought.
Is this a problem with clutch I bought, or the throw out bearing included with it? Or is it normal clutch chatter? Or is it a problem with the input shaft bearing and if so is there a supplier for this part so it can be replaced.
I could live with the noise, I just want to make sure it’s not an underlying issue.
SACHS-MAX STAGE 1 CLUTCH KIT+ CHROMOLY FLYWHEEL for 2001-2006 BMW M3 E46 6-SPEED | eBay
Click here to see description.
www.ebay.com
