Simon Blythe
I think it might be wise to change them anyway at this stage?True that the gaps do look a little big. worth checking
Haven't got a clue thats getting out of my comfort zone.https://www.ebay.co.uk/itm/311675558147
Has anyone tried one of these kits or are they too good to be true?
I agree mate - next action will be to get a new set of NGK'sThose plugs look worn, a new set will more then likely sort your issue.
I need to do mine, had a small misfire under load for the last 3 monthsI agree mate - next action will be to get a new set of NGK's
Halfords, ECP or GSF?I need to do mine, had a small misfire under load for the last 3 months![]()
@Sean d and @g8jka - I've changed the plugs and guess what, she's as smooth as silk. You can tell she's still sucking in air, however the misfire is no more. A double bonus is the fact that the sound system is fantastic too, very loud with a LOT of kick to the bass. A triple bonus if there is such a thing, is that I think I've found what's draining the battery - the window motor has jumped off the runner and continues to cycle when the window is up. Hopefully a reset and that problem will be solved.Those plugs look worn, a new set will more then likely sort your issue.
Hope you might be saying the same to Faheem soon Jim.Way to go! Sometimes we think the worst is going on when in fact if you start with the simple it may just be what's needed!! Glad it wasn't more serious! JIM
Yes, that would be nice for the boy Tony. I''m glad he has you there to coach him along, he seems to get a bit bewildered at times I think but an eager learner to take under you wing. JIMHope you might be saying the same to Faheem soon Jim.
