Simon Blythe
I'm going to do a compression test on the Z later but I'm unsure as to what to disconnect to stop it firing so I can do the test. It's the single vanos engine, can anyone offer a little guidance please?
Cheers Niall,
I've removed all the plugs now and the seem fine. Do I need to disconnect anything else before I connect the gauge and crank the car?
Agree or at least put 5 of the plugs back in and only remove the one on the cylinder your testing or you'll be pumping air/fuel out of the others actually I think thats how you're suppose to do it ie.e.one removed at a time@t-tony will probably confirm but I would pull the fuel pump fuse as well.fuse 18 15Amp and fuse 13 5Amp.
True that the gaps do look a little big. worth checkingDont know if its just the picture but when zoomed in plugs look a little worn
