I guess you could say that when I purchase a vehicle it follows suit that I automatically join a forum or 2. I had an itch to do some wrenching in the garage and the ATV and UTV just weren't satisfying my needs. I picked up a 2001 Z3 roadster with the 2.5i which has seen 207,000 miles. Previous owner for the past 5 years was a guy that was in college and was using this car as his daily driver up until I purchased it one week ago. No maintenance records exist so my first step is to do basic maintenance, replace all fluids, replace thermostat and water pump with a performance version, hoses, belts, and a worn gasket that is causing a slight oil leak. Going to run a compression check this weekend.
I love forums because sure enough one of you has already encountered and dealt with most everything that will be thrown at me by the way of curve balls with this toy.
David
David
My own knowledge be a bit scary though because most of my projects to date have been building lifted trucks and jeeps, for Rock Crawing
Happy Z'ing.
