Been out grovelling on the garage floor this afternoon testing the smaller of the prototypes.
Principle ok and simple to actually fit ( unless old, unfit and dodgy knees
Bent my existing strap to remove it, which was not difficult as pretty rusty ( will probably be an advise on next weeks MOT) and slid in the new parts. You hang the hook part on the carrier, feed the strap through from the back
and line up the studs and put the nuts on .....simples
Fitted it , but needs to be modified at the rear end. Probably due to the material thickness and that both end piece profiles are slightly different.
In the last photo, the bend needs to be about 10-20mm further along which will change the angle. It is a relatively easy fix and there is nothing in the way of it.
I will have a look at the other strap over the weekend and then go in and see the manufacturing company next week to discuss the mods.
I may also increase the width of the rubber cushioning to match the strap. Wont make any difference to price and will be better.
The cable clip also sorted. Easy push in fit.
One down, one to go ......now where’s that Voltarol
PS ........no rear beam or axle was removed during the fitting
