wow top job again,@Low Rider will be made up I'm sure.Saturday update, which of course started with the obligatory bacon butty where we met up with @Oldguysrule for a natter.
From there, it was a trip around Basingstoke in the #ZedShed bus (Audi A2) to collect parts from various locations. Diff bush was at the main post office, and then over to GSF for some more bits, and then B&Q for a new disc for the angle grinder, and then back to pick up my car and then back to the #ZedShed. Nearly 12 by the time we started! That said, we've done this procedure soooo many times now it's down as a fine art.
New beam bushes fitted. When the old one was pushed out, the metal core came out leaving the outer part behind - this is the first time it's happened to this extent. We knew it was bad from visual inspection and the fact you could move the centre with your hand.
The new PowerFlex diff bush. For reference we fit these as they can be installed by hand and don't require pressing in. It's purely for convenience and not that they are better than OE quality rubber for the purpose.
Ready to drop down on to the floor and refit!
Once we got the sub frame back up in place we stripped the rear discs off so we can make sure everything is good underneath them. Err, oops... Quick trip back to GSF to buy some new pads then
A quick peak underneath with the sub frame refitted. The shield behind the discs are badly corroded. Annoyingly the hub has to be removed to change these, so it's not something we do in the shed as it's a real time consuming PITA!
If you have all been paying attention so far you will remember we cut off the rear section of the exhaust with an angle grinder due to the corrosion of the front exhaust flange. The guys at the local exhaust centre suggested this, and the use of 'sleeves' to reconnect it. We'd already picked up the wrong sized sleeves from GSF (someone measured incorrectly in the dark), so went out to get some smaller ones. They didn't have the smaller ones there so a rare visit to Eurocarparts, who had the correct size. We'd already purchased some exhaust cement to make sure everything is sealed and safe.
I had to leave just before the exhaust was refitted, and the essential test drive. Got a text from Lee to say "all good", which leads me to believe your back end issues & over active traction control are resolved now Steve. Hopefully @Lee will update the thread with his test drive verdict soon!
So @t-tony when can we start booking in at the Midlands Zed Shed ltd for these such jobs
Steve.
