Hi All,
This is a thread that I'm creating about a new Corsa 1.3 CDTI that I've purchased, it's a very basic car and is intended to be used on a daily basis for my rather long commute to work.
I purchased the car relatively cheap as the car had been standing on a drive for almost 2 years (this is what the owner has said anyway) - it still has the 2014 tax disc - and the last mot expired in April 2015
When I purchased the car I did so knowing that there may be a few problems, namely:
- Knocking from front of car (intermittent and goes away sometimes)
- Car had been stood for a long time, so possible corrosion in places and poor bodywork.
- Full service history up until 50, 000 - after which there is none - the car is currently at 74, 000 miles
- Puncture on one tyre and low air on another tyre
- Spare wheel fitted in place of tyre
Despite this, I took my chances and got the car.
This is what it looked like when I got it (FYI:- This is the lovely car that fell on me whilst I was lying underneath)
This is what it looks like now - I am still waiting to properly detail the interior of the car and I will update this thread as I make progress on this car
MOT 07.09.16
The car went in for an MOT today and surprisingly the fail list was not as long as I had expected -
I've already asked @t-tony - who should be able to help explain one or two things to me - mainly the issue about the reverse travel.
Things I've done to the Car Mechanically
When I got the car, the first thing was service the car properly. The oil in the engine was *HORRIBLE* Nasty, thick, black stuff.
I then put one bottle of Wynn's fuel treatment into the tank and some premium diesel from Shell - after putting the premium fuel in the knock that I am facing went away (unfortunately, it has returned now).
Also replaced the two front tyres and put the spare wheel back where it belonged.
Now the MOT requires me to fit a drop link - I am going to replace both.
The Dreaded Knock
View: https://youtu.be/68YFMtUNSRM
This is the dreaded knock that I cannot seem to fix at all, even a mechanic (the bloke at the testing station) failed to identify what it is, the noise occurs both when you press the accelerator pedal and disengage the clutch.
I don't know whether this is at all related but for some reason when I start the car, for a few minutes - say five minutes or so - it does not want to rev above 2000RPM - now this may be a safety feature to protect the engine - but I do think that's highly unlikely. The car feels very sluggish from a cold start - almost as though it were in limp mode - but I find that this can be dangerous (e.g. If I needed to pull away quickly or move and the car was sluggish then that could result in an accident.) Again, this is only for a few minutes...
I'll update this thread regularly - or at least do my best to and I'm thinking of creating a similar one for my Project Z
MOT 07.09.16
The Dreaded Knock
