For Sale Pre facelift Auto Hood retro fit kit - complete £135
spurs fan in a coupe
As title
Full set unlike the reservoir and rams that get sold on eBay.
Prefacelift auto electric electronic roof hood kit motor switch, micro switch, ram, clips and torx screws for micro switch
£135 delivered to mainland UK
Yes, but from my coupe, so LHD!
They've also been used whilst doing DIY + painting
They were from Vines in Guildford, can't remember exact price but must have been less than £50 I'm tighter than a duck's arse!
You can't get OEM ///M matts anywhere :(
what is the difference between pre-fl and post-fl for the room bundle?
thanks for that, i do see them about and they quite often say pre or post, been thinking to fit one to mine, got a couple of jobs to do first though. where does the pump power from?
From memory there is a plug that pushes on in the boot, but would have to check tomorrow.
if not i could always use the redundant heated rear screen loom, think thats rated at 30 amps
Lift the left hand trim panel out Jason and on the boot floor you will see the wiring loom, the plug for the roof motor is taped back on itself to the loom right next to where the pump mounts. Undo the little bit of loom tape and the pump plug (with it's wires) is freed, it has ample length to reach the pump. The same goes for the plug for the roof micro switch but this is hidden under the left hand speaker trim panel at the top.
Sorry to hijack your thread Andy.
No worries guys, it's all on topic.
Took some pics this morning
This is the facelift one I have.
