So I’ve been working on ducting for brake cooling which has involved manoeuvring the wheel multiple times to check clearances and so on.
I’m aware doing this introduces air into the system so did start the car a few times and spin the wheel end to end (but was in the air so did not feel the usual judder which I assumes will only happen when the wheels are on the ground).
Anyhow today I noticed that when turning it manually fluid was being ejected from the reservoir.
Quite a bit.
so now what should I do in terms of topping it back up to the correct level and removing air from the system (in the past I just drove it and turned the wheel a lot and it smoothed out).
Quite a bit.
