Passenger side is a new driveshaft yet (old one was given back) but the drivers said hasn't even been off, so couldn't have been refurbished or replaced. Passenger side was also leaking so hasn't even been done to a decent standard. The garage charged for replacement of passenger side and removal and refurbishment of drivers side. We suggested to take it to another garage, even BMW to get a full report of what the problem is and the work that needs to be done before assuming what it needs. The diff was definitely making the noise though, could have been damaged by the mechanic. It was jumping around when we had the rear in the air and was running though the gears.However those driveshafts don't look refurbished to me. Repaired possibly. Refurbished no.
@mrscalex interesting and researched post: thank you. The video is an eye-opener. Looks a massive job to refurb. Rather daunting, tbh. I'm of the opinion that I need to find a Z roadster mechanics course and get myself on it for future reference.I would be 99% certain the ASC bulb has been removed from the dash. People do that to hide errors from the system being flagged by the dash light which causes an MOT fail. Although a keen eyed MOT tester will spot the bulb removal as the light doesn't come up when the key is turned and fails it anyway. People do this because they don't want to or don't know how to fix the error.
When that is done the ABS is no longer operational. You are driving round on a car with no ABS or traction control.
You will see my own experiences here:
https://zroadster.org/threads/abs-not-working-no-error-codes-or-lights.25169/
It's a 10 minute job to replace the bulb. But you are most likely to have errors, probably wheel speed sensor failures to then deal with. Possibly an ABS module fail. Thankfully all easy enough to resolve.
As for the diff/driveshafts. Don't want to say too much more as there are lots of theories and you know you need to get it assessed by a competent garage.
There are also heavy dents on the outer drive flanges which suggests it has been battered back into the trailing arm bearing.
Personally I would find a specialist like one of these to make the assessment with a view to the repair too. This is not a recommendation for these people just what I found googling to show the sort of specialist I would look for.
https://www.mandttransmissions.co.uk/differentials_transmissions_sheffield.html
https://www.hardyengineering.co.uk/
I'd also encourage you to read up on diffs so you can have an informed discussion with them. This shows a full rebuild for instance.
View: https://www.youtube.com/watch?v=qeMIh9mGwRY
That would suggest to me a broken gear tooth. Perhaps draining the oil might show something?Passenger side is a new driveshaft yet (old one was given back) but the drivers said hasn't even been off, so couldn't have been refurbished or replaced. Passenger side was also leaking so hasn't even been done to a decent standard. The garage charged for replacement of passenger side and removal and refurbishment of drivers side. We suggested to take it to another garage, even BMW to get a full report of what the problem is and the work that needs to be done before assuming what it needs. The diff was definitely making the noise though, could have been damaged by the mechanic. It was jumping around when we had the rear in the air and was running though the gears.
I did have some bulbs changed on the dash about 3-4 years ago. I've had my car from new so to the best of my knowledge, there should be bulb/s in situ.I would be 99% certain the ASC bulb has been removed from the dash. People do that to hide errors from the system being flagged by the dash light which causes an MOT fail. Although a keen eyed MOT tester will spot the bulb removal as the light doesn't come up when the key is turned and fails it anyway. People do this because they don't want to or don't know how to fix the error.
Hopefully you are in the 1% of my uncertainty then and have a blown bulbI did have some bulbs changed on the dash about 3-4 years ago. I've had my car from new so to the best of my knowledge, there should be bulb/s in situ.
@mrscalex I sincerely hope so, too.I would think so. The test would probably work off resistance which would be there without a bulb or if the bulb is there but blown.
Hope it’s that anyway. If not might be a fault in the dash panel and you don’t want that.
The driveshaft that is on the passenger side did not look new, or even refurbished, to me. It may be new to this car, but it looks like a second hand unit that has been fitted. There is evidence of it being bashed but there is black paint over the marks, so may have just been sprayed. I have seen spray can 'refurbishments' before.Passenger side is a new driveshaft .
That is not a driveshaft, ........that is a rear shock absorber...!!!!!@mrscalex I sincerely hope so, too.
Here are a few photos of the part I was given View attachment 97435 View attachment 97436 View attachment 97437
Did he tell you this was a drive shaft, I think this is where some of the confusion has come from, as a shocker thats too long will make the car sit high@mrscalex I sincerely hope so, too.
This isn't good. He told me he was giving me the original driveshaft - only took it out of the box today.That is not a driveshaft, ........that is a rear shock absorber...!!!!!
I never noticed new shock absorbers either, and the photos don't show new ones from what I can see, rear shock absorbers are parts that are definitely not refurbished, they only cost about £40 each new. it would cost more in labour and parts to refurbish them than to buy new.
Yes, he said he was giving me the driveshaft back and I've only opened the box up today. He keeps all the parts he takes off in a big storage container. Yes, I had rear new shock absorbers fitted and top mounts.Did he tell you this was a drive shaft, I think this is where some of the confusion has come from, as a shocker that's too long will make the car sit high
I hope this is all a misunderstanding and innocent. Otherwise it’s looking increasingly like you have been turned over I’m afraid.[/QUOTE
Also had the front drop links supplied and fitted. Same mechanic.Yes, he said he was giving me the driveshaft back and I've only opened the box up today. He keeps all the parts he takes off in a big storage container. Yes, I had rear new shock absorbers fitted and top mounts.
