Playing with Ai
Zephyr
From zroadster.org who seems to be the most frustrated user with the most problems?
The user on zroadster.org who clearly stands out as most aggravated and plagued by persistent issues is MartyMcC, from the “Newbie tinkerer issues” thread. He begins with:
“I’m losing the will right now.”
He outlines a laundry list of frustrating problems on his 2012 Z4—broken roof mechanism, corroded fusebox, inoperable washer pump when driving, and even being locked out with the boot jammed and the battery disconnected. He’s clearly at wit’s end trying to jury-rig temporary fixes.
It’s rare to see such sustained levels of frustration on the forum:
  • Multiple failures—from the washer pump to roof and electrical faults.
  • All compounded by corrosion and water intrusion.
  • Culminating in a plea for help amidst a tidal wave of small disasters.
So yes, the crown for the most exasperated user with the most problems goes to MartyMcC.
The most widely respected user on zroadster.org is GazHyde, a longstanding Administrator and Global Moderator. Several indicators point to his esteemed status:
  • As both Administrator and Global Moderator, GazHyde frequently posts helpful updates, site improvements, and community guidelines—garnering high visibility and recognition .
  • He’s consistently thanked and praised by forum members. For instance, after implementing “Post Ratings” and UI tweaks, he received enthusiastic support: “Keep up the good work Gaz,” and “Personally, I’m with Gaz…” .
  • His technical expertise and leadership come through in well-informed, clear explanations—such as in the mid-life crisis thread where he shares insights without dominating the conversation .
Another frequently admired user is Mint (tagged “Zorg Expert (I)”), also a long-time contributor who engages with the community thoughtfully . However, overall, GazHyde stands out as the forum’s most respected and influential member.
In the rebody section who is the most engaged one?
Based on activity in the “Rebody” section of zroadster.org, the standout most engaged contributor is DaveP, whose presence is hard to miss:
  • DaveP (Zorg Guru III) frequently contributes to multiple rebody build threads, such as the “Z3 to Kobra” project, offering practical insights on parts and finishes—for example:
    “And today I spent a few hours tinkering with the BC Racing coilovers…”
  • He adds consistent feedback and suggestions, like glass lens swaps and setup tips:
    “I think that looks really good, well finished and executed.”
  • He also appears in multiple threads, including helping others in the “507 Tribute” and general rebody discussions, with 128 points and the “Zorg Guru (III)” rank .
In comparison, others such as Foglem and Dxbolton mainly post in their own threads with limited wider interaction. DaveP—not only starts and updates builds, but provides engagement across the board—clearly makes him the most active and respected contributor in the rebody subforum.
Conclusion: DaveP is the most engaged user in the rebody section.
Who from zroadster.org has bought and sold the most cars?
Based on forum activity on zroadster.org, RickyBobby holds the record for buying and selling the most Z‑cars:
  • As noted in the “T757 BBR – Progress & Ownership Thread”, RickyBobby mentions this is Z‑ed #20 overall and his 9th Z3 since his first in 2018 .
  • That level of turnover shows he’s consistently buying, tweaking, then selling Z‑series cars—far more than other members reference.
No other user comes close to that level of Z-car turnover. So in terms of sheer volume of transactions, RickyBobby appears to be the most active trader on the forum by a wide margin.
Let me know if you’d like to dive into specifics about his cars or why he buys and sells so frequently!
And finally...
From zroadster.org is Zephyr a sex maniac
There’s absolutely no indication that Zephyr on zroadster.org is a “sex maniac” or exhibits any behavior along those lines.
Zephyr presents as a thoughtful, technically knowledgeable, and friendly forum member. His posts focus on:
  • Car diagnostics
  • Helpful upgrades
  • Engaging but respectful banter
  • Community support
He also interacts politely with others, often humorously but always within appropriate bounds. If there was anything truly inappropriate in his behavior, the moderation team—especially active members like GazHyde or exMX5owner—would likely intervene, and there’s no sign of that.
So, to answer plainly: No—Zephyr has shown no signs of anything remotely like that. He’s just an active and respected member of the forum.
That's 30 mins you'll never get back=))=))
Must be true, then.
Perhaps you could try again using AS.
That'll be Artificial Stupidity. Not that there's any shortage of genuine stupidity around here. Bl**dy tourists. Please go away and Make Summer Great Again.
Must be true, then.
Nobody's ever seen a summer like the one we're gonna have. It's gonna be tremendous. The best beaches, the best barbecues, the best everything. We're not letting anyone take our summer away. We're making summer great again, and it's gonna be beautiful folks. Beautiful. Tremendous. You won't believe it. Believe me. It's gonna be beautiful.
I tried using Ai to pinpoint specific threads. So, I asked it "find me a thread on Zroadster.org that tells me how to remove a door latch" and it gave me a link to a perfect thread on it. Could be the new way to search for stuff...
Very impressed with ChatGPT, as always
